dogsfoot I have a 2015 Subaru WRX and the factory reverse camera uses a 6v trigger. Can I use the factory camera or do I need an aftermarket camera?
dudu-lai You can use the original camera, but you will need a buck module to drop the 12 volts required by the camera to 6 volts.
