dudu-lai trap63 Sorry, I thought it was a 360-degree panoramic camera. It has front and rear cameras, but there is no setting for a delayed display.
Beavis dudu-lai Maybe I should just change the manufacturer of the CanBox? or won't that help either? and any CanBox will not display this information for my car? (mercedes W203 2004)
Beavis dudu-lai there is a homemade CanBox for W203 on GitHub. He can do much more than that. Maybe you can use this? https://github.com/rnd-ash/W203-canbus Or maybe there is a new firmware for my CanBox?
Slavus @DUDU-Meng @dudu-lai https://forum.dudu-auto.com/d/4246-duduos-38-elevate-your-drive-public-beta-rolling-out-260930/49 Could you please address this issue? The Vgate iCar Pro 2s worked correctly in all possible modes (ELM327, vLinker MC+, and "original car equipment" mode) prior to the update to version 3.8beta. Since the update, when using vLinker MC+ mode, it takes a very long time—sometimes over ten minutes—for engine RPM and coolant temperature readings to appear, and the fuel level never shows up at all. In ELM327 mode, the iCar Pro 2s fails to connect entirely, while in "original car equipment" mode, engine RPM appears almost immediately, but other data—such as coolant temperature or fuel level—is missing. A factory reset does not help, and I am unable to downgrade from the current version (3.7 20260430) to the official version 3.7 or any earlier ones.
dudu-lai Slavus Vehicle information displays only data from the CANbox; OBD data is not shown there. OBD information is displayed in the widgets. Slow display: It is highly likely that the OBD device is not sending this data to the DUDU widget. You can test this by connecting the OBD device to your phone and using its official app.
Slavus dudu-lai i mean vehicle information on status bar and widgets For ELM327 option vgate icar pro 2s won't connect, before update worked For vlinker MC+ connected, but not showing fuel, coolant temp or engine RPM in widget, after several minutes can show RPM and coolant temp, but fuel not For car equipment mode - engine RPM works well as before uodate, but status bar fuel ir coolant temp are empty After several minutes shows this, fuel still unavailable And how can i downgrade to 3.7? It is impossible to me
dudu-lai Beavis I'm not sure either; the prerequisite for all this information is that the original factory screen is capable of displaying these functional details.
dudu-lai Slavus Please follow my method to connect your phone to the OBDII unit; this will help determine whether the issue lies with the OBD device itself or with DUDU.
N0_skill So Day theme when set to dark still shows light backgrounds in dudu OS how hard this is to fix ? I want dark theme all time but at night use extreme dark due to screen being to bright. If you cannot fix this at least add option to trigger extreme dark with headlight ON/OFF There is option for reverse gear....
Benlatak N0_skill @dudu-lai @DUDU-Meng It is the idea I want to expose... "extreme dark mode" could have a switch to turn it on when headlight is on. PLEASE !!!!!!!!!! And another thing, feedback of 3.8 beta on this topic = OK But for special request or real bug = dedicated topic or here on this topic ? Thanks a lot and keep going on this good work 😉
Cleyoo N0_skill there is a menu in settings where you can switch it to stay at darkmode all time , 3.7 had it and 3.8 also have it.. i cant say it out of my head right now , but try to surch it in settings there is a sub menu where you can switch it to use all time darkmode , it is there
Tomasz898989 i like the Update, it is a good step into the right direction. however i have some Problems with the new status bar icons. i have the P R D icons but i have a manual gearbox. so it should be 1 2 3 4 5 (VW Golf 7). also the left and right arrows do not work in the Status bar. but the animation itself is supported by my Canbus (Raise) the yellow animation at the left and right of the Radio works without a Problem. the PDC animation is different now when parking when the obstacle is in Front but maybe i have to Check the settings
Fuennik I set the modified key on my streering as front 360 camera, i notice that the home button of my SWC is not working after the modified key is press
Beavis dudu-lai The original factory screen is Mekede 🙂 (Your production 🙂) These functions didn't work on it either, but you yourself wrote in the announcement: " Extended CAN-bus protocol compatibility covering approximately 70% of popular car models worldwide. For the latest list of adapted models and CANBUS protocols, please visit: Announcement of Deeply Adapted Vehicle Models & CANBUS"
Migel dudu-lai А мне вы что ответите? С помощью телефона я проверял и всё отображается а на Dudu7 только температура антифриза, бак в % и напряжение
Slavus dudu-lai i know it is DuduOS problem, lots of posts on telegram are similar after update, my OBD works fine with phone. Till 3.7 260430 was perfect with OBD2, 3,8 beta - oh no.. . Today i'll try downgrade to 3.7 260126 and let you know.
