Hello
Dudu7 is set to sleep mode, battery when i take the key out is around 12.5V and after 2 days it is drained to 11.7V
When i turned the key and started the motor dudu7 was not shutdown so it was still in sleep mode at 11.7v and car had a bit of a struggle to start the motor.
I have also installed rear parking camera connected yellow to dudu7 rear camera and powered it to red camera 12v wire. In options it was set to always power rear camera. Can that be the issue?
Have macrodroid with one macro monitoring hotspot and when wifi is available it restarts waze to enter online maps mode.
Harness was bought online specifically for my car vw tiguan mk2, and canbus is Raise, and it is recognising doors, sensors and wheel buttons.
I have set it to shutdown now and set reverse camera always on to off option. Will monitor if the battery is still draining.
I would appreciate some ideas and help with my problem.
Thank you
