HAccord8 Anyone used this for dynamic reverse line? Do you need to get rid of existing canbus box? https://drive.google.com/file/d/1PO41UGKeq3IauNOhEDIFg-4R7NzHp3S2/view?usp=drivesdk
HAccord8 dudu-lai they are saying it can be used https://drive.google.com/file/d/1nh48itKtvuIlXMH1emLDbZJc39AVphUY/view?usp=drivesdk
HAccord8 dudu-lai i bought a different one instead and they asked me to connect the wires to the 10 pin connector to RXD and TXD and asked me to select XZMGuiji from External Serial Port Device but no luck, the only way to make it work is to remove RAISE canbus then connect 8 pin connector on CAN_RXD CANBUS TX and select XZM > OTHER > GUiJI > XZM from CANbus selection which ends up RAISE not working. Do you want CANbus logs to see if something can be done please? https://drive.google.com/file/d/1PMdbfJf0qmAQgD8iUL_YN_GtupDz2LHV/view?usp=drivesdk https://drive.google.com/file/d/1KSb3JjZXpm6cIIwJy7SNk0JNDsqWrJtp/view?usp=drivesdk https://drive.google.com/file/d/1pAbuiJCPQ6fzzNUA6UK0mMX_TcZYhiYp/view?usp=drivesdk https://drive.google.com/file/d/1mGLbuqKz_KSx52ZF4HtZBaRZ_HGYK26N/view?usp=drivesdk
HAccord8 The TXD line on 10 pin connector started to get data from XZM as soon as i turned on/off BSP Serial Debug option under Developer Options. Now both XZM and my RAISE CANbus box's can work simultaneously
