• Update Bulletin
  • DUDUOS_DUDU7_Global_241008 Update!
One suggestion:
Can it be possible to add USA or North America to the region?
Thanks
    moreyruiz
    This region is not for phone/SIM or wifi. It is for the download servers. Users from Russia did not have access to the Chinese servers. So dudu added a few extra servers to cover the entire world.
    You can simply download from the European server.
      surfer63
      Do it doesn't matter what server I have? I'm from Poland and I have Russian server in unit info.
        A thing that I noticed is the AC temperature.
        I selected the Fahrenheit (F) but the System continues displaying Celsius (C) after the number.
        The numbers by itself matched the Fahrenheit temperature set on my AC, it just the letter. Istead of display the F it display a C.
        When I go back to the radio settings to verify what I previously selected (F), it is reverted to (C).
        Ej.
        If my AC is set to 65 degrees Fahrenheit, intead of display 65F the headunit display 65C
        Thanks
        Gwinambele
        It should not be a difference which server you chose. Theoretically the server closest to your location should be the fastest for you.
        5 days later
        JhonnyD I also am missing this and I used it regularly to adjust subwoofer volume level. Please bring this back!!
        mo_danish hey mo, er du dansk? 🇩🇰 Hvilken enhed har du? Har du nogle offentlige post på feks Instagram med billeder mm? Mvh PEM
        Rød grød med fløde
        4 days later
        YAOXILONG I cant download toppal also i have the latest firmware 241008 on my dudu7. When clicking on toppal update via the OTA update nothing happens. Any solution thank you
          10 days later
          YAOXILONG
          Hi,
          Can't seem to get download to work keeps saying "Update verification has failed! Version may be too old or the file has been modified. Please retry download and try again." I did remove the "updatecfg.txt" as to not lose my data and rezip'd the file back up and tried the download. May that be what is causing the issue. I'm on version: V240927. I wanted to update because of issues I'm having with PIP not opening up and thought this update would fix the problem.
          Thank you in advance for any advice you can give.
            Neoj5680
            Keep the files as unpacked in the USB(only the files, not the folder) and don't go to OTA menu to update. It will automatically detect the upgrade files.
            Neoj5680 Download the zip with the latest update. Extract it somewhere (I do it on the desktop). Copy the files from the folder (not the whole folder) to a FAT 32 formatted USB drive and delete the updatecfg.txt (from the USB drive). Insert the USB drive in to the USB port connected to the unit and it should tell you that an update has been found. Good luck.
            When you acces the USB drive it should look like this.
            If you still getting that error try to re-download the zip update file.
            @Neoj5680 And once the update finishes and the screen is prompting you to remove device.....remove the USB drive....ignorant me assumed the message was to reboot the head unit and since there was no menu screen for me to select reboot I disconnected my car battery.......then it went thru the whole install process again and it was then that I realized it meant to remove USB device. 🙂
            a month later
            DUDU-HUANG unmarked the discussion as super sticky.
            5 months later
            mo_danish Hi there! FJ cruiser owner with Dudu7 installed, just wondering how your head unit integration went?
