• Enable border round menu
I'd like to add a feature that makes the corners round like the screen on the Apple MacBook. When the round feature is added, it's even more
The UI will look luxurious.
    biggom27 This is a matter of theme, not system. You can set yourself one with rounded corners
    The bezel on the DUDU LCD panel is black. I don't care about the border line on the curved black screen, but in bright themes, I think the system can be changed more luxurious if the line of the liquid crystal exclusion is rounded rather than perpendicular. There is also a separate app on MacBook that connects the normal monitor and makes the border area round.
    I'm talking about the curvature treatment of the bezel on the border of the system, not the navigation menu on the screen you showed me.
    It's not about changing the UI of the system itself. I think if the following design is applied to the top of the existing system, the UI will be changed harmoniously with the black liquid crystal exclusion even on a bright theme.
    I think it can be managed in the form of on/off.
