dudu-lai Jaggen Air conditioning data available. Is the air conditioning floating window enabled? Please update the APK and try again. https://drive.google.com/drive/folders/1xtLiKSIvZklzLSZz7XlTDzBtWu5-vRtv?usp=sharing
Jaggen dudu-lai Worked! Is it possible for the pop-up to be the one from Duduos? I don’t have those readings yet Thanks
dudu-lai Jaggen The CANBUS box does not support this information; please access the original vehicle system via the AUX app to view car information. (The factory system is retained.)
Jaggen dudu-lai thx. Please add it to the whishlist. Generally, the change will apply to Mercedes W204 (C-Class), W212 (E-Class), and W218 (CLS) models, since they use the same electornic platform.
Jaggen dudu-lai Hi, why isn't the temperature showing up in the bottom bar when I'm already getting correct readings from CANbus? Can you help?
dudu-lai Jaggen The photo shows the initial version of the air conditioning pop-up window; to display air conditioning information in the navigation bar or the new AC UI, compatibility for the specific vehicle model ID will need to be added in a future DUDU update.
Jaggen dudu-lai Thanks, and when can I expect an update? It’s a bit odd, because in my other car (an Opel Mokka) everything’s worked fine from the start, but here, in a more popular car, I’m constantly running into problems.
dudu-lai Jaggen There is no specific timeframe; this post will be updated periodically. If your vehicle model ID is included in the update log, you can download the attached APK for testing.
Newerty Rageking16 dudu-lai https://drive.google.com/file/d/19hYx0Uf-eOCCg76ethM9utDze6qRbAtM/view?usp=sharing Sorry for the late reply. I’m using the version from the quoted message. I haven’t tested the newer ones yet, but if you try them, let me know how they work 🙂
JhonnyD davidedie01 Bosch SLDA or Suzuki Connect? We have Bosch SLDA and have to use canbus module with OBD. I am waiting to. But DUDU first will implement big car makes.
Mari coco80 Hi, for Honda Amaze 3rd generation ZX-CVT (2025 model) current running model, CANBUS is available?
