dudu-lai
Hiword-Song
Thanks guys for your work on this. Here is the current situation:
a) There are still no Climatronic readings. Nothing is displayed on the screen. Neither the factory CANbus window nor the launcher popup. Overall, there's just no climate data coming through.
b) Also, when I press the physical radio or climate control buttons, the volume still drops down by itself.
c) There is some small progress with the parking sensors, though. Here is how it works now:
If I shift into Drive and release the parking brake, the front sensors work just like on the OEM display and are visible on the DUDU screen. That’s a step forward.
When I shift into Reverse, both the front and rear sensors show up properly. However, if I shift back into Drive after being in Reverse, the factory sensors keep working, but the overlay on the DUDU screen stops working.
I also found one more bug:
When the sensors are triggered for the first time, only the boundary line appears (as seen in the picture). In this case, just the red line. The yellow and green zones are not filled in. When in Reverse, all the zones fill in correctly.
