Hiword-Song
@dudu-lai
OK, after a long search, I managed to find bz13.20. However, I am having some issues. I want to point out that I selected the correct CANbus profile—besides, I only have two to choose from, and it's the exact same on both.
The pop-up window doesn't appear, even though it is enabled. The system also isn't picking up any readings from the Climatronic panel.
The OEM head unit works exclusively as a passthrough for the knob in the center console; the speakers and the rest are connected directly to the Dudu unit. When I have the OEM head unit turned off, turning up the volume via the knob only works for two or three levels and then it stops working. But when I turn on the radio, the knob works perfectly across the full range. However, when I change the Climatronic settings, the volume also changes. With the OEM head unit turned off, this doesn't happen. Will you be updating this? Thank you for your help.
Edit:
I found one more issue. The window with the large car and parking sensor display doesn't show up (it only appears for a moment after starting the radio and then disappears). When I put it in reverse, the rearview camera activates along with a small car view, and the sensors are visualized there. If I pull up moving forward, the window with the sensor readings is not visible. I have a comparison with the Raise CANbus and it worked there, so it is definitely possible.
