• Bug Feedback
  • Issue when I turn the steering wheel the line stay fixed in the 360 camera
For more efficient feedback on bugs, be sure to provide the following basic information to reduce communication costs
[1] Describe in detail the error you encountered.
[2] Provide screenshots of system information, in the car settings - about - long press the upper left corner of the picture for 3 seconds, the contents of the pop-up window to take pictures
[3] Whether the bug can be reproduced, reproduced is what the steps are
I have a problem when I turn the steering wheel the line does not move right or left depending on the steering wheel stay fixed in the 360 camera application attached the photo which shows this bug ?
    Amin89 для предоставления информации о системе нужна не эта фотография. Нужно нажать и удерживать на место, которое я выделил. Появится всплывающее окно. Вот его фотографию и нужно сделать.
    Представьте пожалуйста эту информацию.
      Chubaka885
      Here are the photos off the details off the devise Dudu 7 you ask to resolve the problem thank you.
        Amin89 ваша машина имеет датчик угла поворота руля? (Например систему курсовой устойчивости). Если нет датчика положения руля, то поворот линий (динамические линии) работать не будет.
          Chubaka885
          yes my car is equipped with the esp (stability control system) before the car radio Dudu 7 it works with another android car radio the (dynamic lines).
            Amin89 хорошо, @caolz bug?
              Chubaka885
              the bug is the (dynamic lines) don't work with turning the steering wheel in the application 360 caméra.
              i have same problem that the steering wheel line stay fixed , before it work on my old head unit teyes cc3.
              i confirmed again that after update beta version of OS, it fixed , line is change following wheel
                jacob thank you for your feedback waiting for new version Dudu 7 coming 24/09/2024 for resolution off this problème.
