Title: Hiworld HYL3.20 on 2015 Sonata LF (Sonata 9) with Infinity amp: CAN2 wiring and Tune knob
Setup
Car: 2015 Hyundai Sonata Limited (US, LF / "Sonata 9"), factory Infinity amp, 2.4L
Head unit: DUDU7, CANBUS profile Hiworld → Hyundai → Sonata 9 → 2015–2017 HIGH
Box: Hiworld HYL3.20, replacing a Raise RZ-HYK63 + HYK64
Audio: DUDU coaxial SPDIF straight to the amp (M09-4A pins 6/15/5); HYL SPDIF and AUX pins not used
CAN1 on M-CAN (M09-4B pin 1 High, pin 13 Low). CAN2 (20-pin pins 14/18) not connected yet
Working: audio, steering-wheel buttons, panel keys, volume knob, camera trigger (REV-OUT → G5)
Questions
CAN2 bus: for door status and reverse guidelines on the Sonata LF, should CAN2 connect to C-CAN (M09-4C pin 2 High / pin 1 Low) or B-CAN (M09-4C pin 11 High / pin 12 Low)? On this car, the OBD port's pins 6/14 are vehicle speed and FlexRay, not CAN, so I don't want to use the generic OBD harness.
Tune knob: the right Tune knob is wired to ROT2 (20-pin pins 3/4) but does nothing, even in the FM app. Is ROT2 supported for this profile, or does it need a setting?
Dashboard clock: the dash clock shows a time, but it never updates. When I change the time on the DUDU (manually or for daylight saving), the dash clock stays at the old time. Does this profile support sending the time to the dash clock? Does it need a setting, or the CAN2 connection?
I can post photos of the wiring if that helps.
