@Hiworld-JACK @Hiword-Song
Hi team,
I have a 2021 Peugeot 3008 equipped with the factory OEM Focal audio system (CANbus-controlled external amplifier under the passenger seat) running a DUDU7 unit with a Hiworld CANbus box.
The issue:
When increasing the volume, the Focal amplifier abruptly cuts off into protection mode (protect/clipping) well before reaching the volume level/dynamic range that the factory NAC head unit was capable of delivering.
Technical context:
On the PSA Focal setup, the factory NAC unit outputs a low/line-level differential signal, while the actual master volume/gain is controlled directly inside the Focal amplifier via CANbus frames. Currently, using the DUDU7 internal speaker-level outputs over-drives the Focal amp's input stage. Lowering the internal Android audio gain prevents the clipping, but severely degrades the overall output power and dynamic range because the Focal amplifier's internal master gain remains too low over the CANbus.
Request:
Could you please add support for OEM Amplifier Gain / Master Volume control over CANbus in the Original Car / Vehicle Settings (or CANbus settings menu)?
Being able to properly adjust the factory Focal amplifier's CANbus gain/volume curve would allow us to feed a clean, unclipped line-level signal while restoring the system's full power without triggering the amp's protection cutoff.
Thank you for your support!
