Hi ,
I've installed a Hiworld FD01.10 (with buzzer) CAN-bus adapter in my 2008 Ford Mondeo 4. The head unit is a DUDU7 (12GB RAM / 512GB ROM) running DUDU OS 3.7.
What's working fine through the adapter:
Steering wheel controls – volume up/down, track prev/next
Climate control – full display and operation via the HU
Radio – frequency and station info
Media playback – track number, artist, title on screen
Reverse camera – auto-switch when engaging reverse gear
Headlight detection – button backlight dimming automatically
Problems I need help with:
MODE button – currently it cycles through audio sources (Radio → BT → USB → etc.). I only use Spotify, so I want to remap this button to Play/Pause or Mute. Since the buttons go through CAN (not resistive Key1/Key2), the standard SWC learning menu in the HU doesn't allow remapping. Is there any way to reconfigure this button on the adapter itself? Maybe a firmware update or a config tool that lets me change button assignments?
Door open status – the HU doesn't show which door is open. Does the FD01.10 support door status monitoring for the Mondeo 4 (2007–2014)? If yes, do I need to enable something in the HU settings, or is there a separate wire that must be connected?
Parking sensors – front and rear sensors are not showing up on the screen. Does the adapter support parking sensor integration for this car? If so, what's the correct connection method (CAN‑bus or additional wiring) and which settings should I turn on?
I've double-checked that the adapter is set to "Hiworld" in the factory settings of the HU and all connectors are seated properly.
Would really appreciate any advice from those who have a similar setup. If you have a firmware update or a configuration utility for this adapter, please share a link or instructions.
Thanks in advance!
