Hello DUDU team,
I have been using internal DUDU TPMS sensors for about 6 months without any issues.
About two months ago, during a tire change, one TPMS sensor was physically damaged.
I purchased a new set of DUDU TPMS sensors and installed only one new sensor to replace the broken one.
Important details:
3 sensors are old (from the previous set)
1 sensor is new (from the new set)
The TPMS receiver is still the old one
Problem
At the moment:
3 wheels show correct, live pressure values
The wheel with the new sensor shows the last stored value from the old sensor
That value does not update, even when driving
So the system looks like all 4 wheels are OK, but in reality one sensor is not communicating.
Questions
How can I pair or bind one new DUDU TPMS sensor to the old TPMS receiver, so that all 4 wheels work correctly again?
Is there a manual pairing / relearning / reset procedure for mixing old and new DUDU TPMS sensors?
Important feedback (very impractical behavior)
This behavior is extremely misleading and unsafe:
If a sensor is missing or not detected, the system should not display old memorized values
It would be much better if:
The wheel shows “no signal / error”
Or shows no value at all
Or at least displays a warning that the sensor is not detected
Right now, the user can easily think the sensor is working while it is actually offline.
👉 Please consider revising the TPMS logic in future firmware/software versions to handle missing sensors properly and avoid misleading data.
Thank you in advance for your support and clarification.
Best regards
