DUDU-Meng HAccord8 Bluetooth phone or CarPlay calls? Have you tried using Google Maps during a call? Does it have audio?
HAccord8 DUDU-Meng yes both Bluetooth or CarPlay call. No i dont have google maps or did not try that
HAccord8 DUDU-Meng Yes so i test Google Maps and same issue with Google Maps, the audio stops for Navigation when on call via Bluetooth or CarLink
DUDU-Meng It has just been confirmed that calls have the highest priority and will cancel all other sounds. This is how it was designed.
HAccord8 DUDU-Meng can you add it as a future feature request please? The ADAS warning and Navigation warnings are also important.
hafiz_tahir DUDU-Meng may i know it this latest version is official build? Why it is not pushed when checking for dvr2k app version update?
hafiz_tahir DUDU-Meng noted, may i know how to check for update? When click the app version it says no update available. Do i need to ask in here every fixed interval like 1 month?
DUDU-Meng hafiz_tahir The latest versions available on the forum are all test builds. Only the official release will be pushed via OTA. Test builds must be manually extracted to a USB drive for installation.
hafiz_tahir DUDU-Meng understood, so if i want the official built, i have to wait untill it is pushed to general public via apps about update. Noted
jerome80 jai tester jai beau changer de canal jai pas les alertes sonor jai tester de 1 a 7 pour voir en roulant pour l'instant jai aucune alerte je testerais les autres canal quand je roulerais dans la journée
