  • crash application 360 Dudu7, message "3D RoundView System is not activated" ?!
Hello, i got a message in the the application 360 caméra Dudu7 "
For more efficient feedback on bugs, be sure to provide the following basic information to reduce communication costs
[1] Describe in detail the error you encountered.
[2] Provide screenshots of system information, in the car settings - about - long press the upper left corner of the picture for 3 seconds, the contents of the pop-up window to take pictures
[3] Whether the bug can be reproduced, reproduced is what the steps are3D RoundView System is not activated" and the application crashes every time how to activated and fix this crashes application 360 caméra please ?!
Authorisation update after connecting to the network
    dudu-lai
    Yes but when i press update autorization i get a message ´please activate the machine first‘ how can i activated the machine please ?!
    Restore the system to factory settings and see if that fixes the problem.
      DUDU-HUANG
      I restore the system to factory setting and the same probleme How to active the machine DUDU 7 ?!
      21 days later
      I cant find the app to launch 360 camera on dudu7
        Ali If You have 6/64 version of Dudu 7 it doesn't come with a 360 chip. So no 360 app. Did you select on the initial configuration steps that you bought 360 cameras?
        8 days later
        i have same problems with the application 360 caméra gives me the message to activated and i cannot choose new cars and some time the 360 application it restarts again on its own what he can be ?!
