• Bug Feedback
  • Navbar A/C control
[1] Controlling the air conditioning is not possible.
[2]
[3] on Navbar
    PatrykWaw
    Your car is Peugeot/Citroen.
    The air conditioning control protocol and some other control protocols for this type of vehicle have not been connected yet, and the air conditioning cannot be controlled temporarily.
    This issue will be addressed in the future.
    9 days later
    Is there any (future) way to change the AC settings right on the screen instead on the phycial buttons?
    I'd guess though that it's not possible because the CAN data can only be read.
      HondaCivicDriver
      If you have already bought a CAN Bus Decoder(CANBUS box), then Setup>Vehicle>CANBUS>CANBUS>Select Your CANBUS Model.
      Then you can control the air conditioning or other vehicle settings through the Vehicle settings application.
      The Vehicle settings application is an old application that connects to many CANBUS boxes and can control multiple brands of vehicles through CANBUS boxes.
      The Vehicle Details application is a new application with a more user-friendly interface, but the number of connected CANBUS box models is less than the old application and will increase in the future.
      If Setup>Vehicle>CANBUS>CANBUS>Select Your CANBUS Model and open the Vehicle Details application and see a different interface than the old application, it means that this CANBUS box has connected to the new application.
      Otherwise, you will jump to the old application interface.
      If you select a CANBUS Model and it has connected to the new application, you can also use the air conditioning control button on the Navbar.
        7 days later
        caolz I have set up my Canbus box successfully. It's all working and the Vehicle Details app is showing a new car with AC settings that I can click on and which also switch between on/off etc. after I press a physical AC button.
        But still, I cannot click there to change the AC. That's still only possible by the buttons for me.
