Alex83 I can't use dual pip get this message "dual pip conflict dual pip is disabled by default" And my dudu7 unit change volume by it self inte all apps so it's the unit not the apps do it in Spotify. YouTube and radioplay app
DUDU-Meng Alex83 Two PIPs cannot run the same app simultaneously. This causes conflicts. We've received similar feedback before: when you select an app in Navigation PIP and then try to select it again in PIP123, a conflict warning appears.
abidali DUDU-Meng Not trying to hijack this thread but wanted to ask if I can only set two PiP on minimalist mode? There are 3 and I don't see an option to remove one PiP.
abidali DUDU-Meng That is obvious solution but when left window is enlarged and right window is small, enlarging right window also result in showing third window. Why not the option to just remove one of them?
DUDU-Meng abidali Design Drawings The minimalist mode consists of three plugins, with no requirement to remove any. If you don't need all three plugins, you can use the dual PIP mode.
