Is there a way to reset the factory TPMS system for a VW Golf Mk7.5 in DUDUOS?
I am using a Raise CANBUS which seems to work well and is getting data OK. I have just had new tyres fitted and the VW TPMS warning triggers on the dash on startup (This is the basic "calculated from wheel rotation" version, not an actual pressure monitoring system) . At the same time a pop up appears on the DUDU7 headunit with an image of the car and "normal" by each tyre, so the CANBUS interface is getting and understanding the message from the car at least, but there is no reset button on it that I could find.
I have also looked in vehicle info and settings etc but can't find a TPMS reset button so far.
I do have OBDEleven and presumably can reset it in there, but if it ever happens while I am on a road trip it would be much better if I could reset it through the DUDU7 as I could with the old OEM headunit.
Any help or tips greatly appreciated
