Please implement BLE TPMS through the default bluetooth! that is very common in the car industrie.
BLE TPMS
I asked for the same, i think.
JhonnyD
If BLE Bluetooth is enabled which is also by hispo devices than it is simple only an app which can read the data and who can be set as default TPMS app or an implematation in dudu os.
JhonnyD
This is the app which i was use on my Hizpo device.
https://play.google.com/store/apps/details?id=com.sysgration.tpms.app
This can read OEM TPMS?
OK. Just for 3rd party Bluetooth TPMS.
In my post it us about oem 433Mhz TPMS we have to use in Germany.
JhonnyD
Oem TPMS is a wide discryption but i think the app can.
The case is that 433Mhz is a frequency default not used by tablets, phones, headunits and so on.
So you have to buy a unit which is compatible with android and use usb, so there could be a translation from 433Mhz to data so the application can give you the data.
In my case the tpms airvents are communicating with BLE which is common in bluetooth sinds version 3.0 and therfore is asked DUDU where i can set it to on or is that the default because i can't find anything in the settings.
Regards,
Arjen
JhonnyD
Who say that you have to use that specific 433Mhz or is that common by car industrie because by tire shops the most common tpms sensors/airvents are BLE TPMS
Yes. Our government says it is a must have for Cars sold since 2014.
So i think nearly all car brands sold in Germany uses 433Mhz preinstalled.
It's build into the cars system or canbus and if you cancel it or uses another system you may not drive the car anymore...
Not everything is perfect in Germany anymore.
you have to google for usb unit witch can read 433Mhz TPMS than it will work if you have the right app with it.
I think there are a lot of opportunities.
No. I don't like external Sensors.
Like i said i am using a usb device that can read 99% of OEM TPMS sensors.
And DUDUAUTO just have to adapt the TireMoni apk to their widgets
JhonnyD
You have a choice between external and the common internal 433Mhz TPMS sensoren.
I think we don't understand each other.
I have oem tpms which i have to use or car in the trash.
I searched for a device that can read the installed code from Suzuki and found TireMoni that can read it.
So i bought their device and used theit app. So i just have one system of sensors and have no need for 3rd party sensors.
DUDUAUTO just have to adapt the TireMoni app to appear in their widget
And the TireMoni receiver can read 99% of all available OEM TPMS
Okay,
and the Tiremoni device can connect throught usb with de headunit?
Yes
And is there anything new about the Tire Moni system?
Unfortunately not.
Maybe in the future. I have been told that the focus is on the firmware at the moment.
