Will-Survive akoni if you want the double din version of dudu7 then a generic double din adapter/fascia from metra or other brands will work
bastelfrosch Hello, I have a 2022 Fiat Ducato 8. I don't have steering wheel buttons, but I would like to have the door information in the Ducato 7. Is there a CAN interface for this?
Steilein MihaiFlorin Thank you very much for the clarification, the screen size is now clear. I still have a few questions regarding the CAN bus adapter. How exactly does it work? Is it mandatory to use one in order to get vehicle information? I noticed that some sellers offer only the frame (fascia?), others include the frame with adapters, and there are also listings for just the adapters separately. Is there a recommended adapter? Thank you again!
MihaiFlorin Steilein It depends on the car that you have. There are cars with CAN Bus and without. For those with CAN Bus you need that adapter. Normally your seller should know if you need that adapter or not but it's not guaranteed. Better to get on the Telegram group and to ask there under HW installation thread.
Nicolas Bonjour, J’ai regardé les liens pour acheter en Europe mais le modèle Dudu7 12G 256Gb n’est pas disponible en stock. Vous n'avez pas où je pourrais l'acheter en Europe ? Merci beaucoup pour votre réponse
NeySlim Nicolas https://www.alibaba.com/x/AztnN9?ck=pdp Official mekede french stocks. Received mine in 5 days.
Nicolas Bonjour, Est-ce que le vendeur Boutique DUDUAUTO-TECH sur AliExpress fait partie de vos revendeurs officiels ? Merci beaucoup pour votre réponse.
Nicolas YAOXILONG Est-ce que le vendeur Boutique DUDUAUTO-TECH sur AliExpress fait partie de vos revendeurs officiels ? Merci beaucoup pour votre réponse. Is the DUDUAUTO-TECH Shop seller on AliExpress one of your official dealers? Thank you very much for your response.
Nicolas NeySlim C’est une boutique officielle ? Car il y a beaucoup de copies. En plus il est noté universel et j’ai besoin du canbus pour Peugeot.
NeySlim Nicolas n'importe quel faisceau + canbus android peugeot compatible avec ta voirture fonctionnera
Janebo Is it safe to buy from DUDUAUTO Flagship store on AliExpress?, I ordered a DUDU7 128/8 GB 360ic, Problem is that tracking never update, it say waiting for seller dispatch, seller says he shipped the unit
amjadnaz Hi there, just wanted to check if this is one of your store as well, i ordered a DUDU7 unit form here recently so just wanted to check if this is one of your stores https://www.aliexpress.com/store/1103131363?sortType=bestmatch_sort
Benbound Hi I need to fit an 11.5 inch DUDU7 Universal to a 2015 Mitsubishi Outlander PHEV. I have all the hardware and brackets for the OEM head unit - is there room to access the screws to mount the head unit and fit the brackets to the OEM mounting holes- if anyone has done this or has photos that would be great- is a fascia adapter needed?
zukispeed @YAOXILONG How do I know if I have the 360 chip? I have the plug? I intended to add the 360 cameras but cannot find the avm module, I can find the cameras but not the avm
hrotkuc Hi I bought it on AliExpress and the LCD had an initial defect. Support told me that there is no exchange or repair program and I can only get a refund. This after it took 2 weeks to arrive. I wish they would inspect the product properly.
