In minimalist mode, If you listening to the music with external app (Poweramp/Spotify). You need to set Music Widget to Auto-Adaptive or those specific apps so the music info will shows up.
But, if you somehow want to listen to the radio and decide to open default radio app, choose a station, then back to home menu with widget, Music Widget will not show the Radio Station Info from default radio app. And you need to change the widget from Auto-Adaptive mode into Radio Mode Manually.
So I would like to request to allow Auto-Adaptive mode to also get the Radio Station Info from default radio app. So I don't to have swap it manually.
Or make Music Widget to catch current audio source automatically would be the best. If I open FM, change Music Widget mode to FM, And if the audio source is not system default, change Music Widget mode to Auto-Adaptive.
