yulayli Hey, mate! I know it might be unit or car dependent, but if it helps I’ve looked into this and I found the following current draw:
- First 20 seconds after ignition off the unit draws between 0.6-0.8A.
- After 20 seconds it falls to 0.002 and stays there until next ignition on cycle with no fluctuations.
Assuming everything else is healthy with your car, this draw will take around 7-9 months alone to drain a 50Ah battery.
My car has around 0.02-0.03A draw when off and on a 70Ah battery it will take around 3 months to make it completely flat.
Was not able to test after how long the HU turns completely off, but with this draw in sleep mode you are more than safe.
