I purchased the single DIN 13" unit. Popped it into a double din mount in my vehicle with the other din hole filled with a cubby pocket behind the screen in the dash. I had a real problem connecting the cable to the display unit. They did not really use the best method or location to connect the wire harness to the LCD unit, it is in a position where the socket on the LCD display can easily be damaged. Also I find the the display is a little wobbly after being connected, it doesnt generally wobble when I hit a bump but it does give way on the far edges when you need to touch the screen at the extremes. If they have a preferred method to help avoiding damage while connecting the display or a way to prevent the light wobble they should include this info in a paper insert in the box when you install but do not. I am not saying dont get the unit. So far I absolutely LOVE my single DIN and am very impressed with it in every other way.
Nick
