Hi, I have some feature request for Navbar and A/C Control Panel.
For A/C Control Panel:
- In Pop-up mode: resize vent control for a bigger one (or add a setting to choose small and large).
- In Pop-up mode: Actually, if time out delay is set to 5 seconds, whatever i do in pop-up panel, it close after 5 seconds.
Adding an code to start time out delay after last press.
- In Full Screen mode: add a auto-close timer (like pop-up mode).
- Ability to choose between the new and old A/C control panel with a switch, "use new A/C Control Panel (for compatible vehicle)" in dev settings, for example.
For Navbar:
- In Navbar A/C control: Resize arrows for more confort:
Or make the same thing than vent control: press on temp open a tiny enlarged pop-up to change temp, for more confort:
- Add external temp option in Navbar, in front of time:
For Bluetooth:
- Ability to personnalize Bluetooth device name, instead of "DUDUAUTO".
Thanks
