dcooksey Yes, you can use a USBC to 3.5mm or USBA to 3.5mm and connect it to your car's AMI connector via the AMI harness sent by the seller.
One thing to note though is that it doesn't have a direct audio output, you'll need a USB DAC decoder that converts to 3.5mm output!
