• DUDU on Junsun v1 Pro
Hi, I installed the DUDU Launcher on a Junsun V1 Pro head with chip 8667 8RAM/128ROM, it works fine but I want to tweak a few things, firstly I am using a Deelife MU9F, from the TPMS menu I selected the Thisrd party app but the data is not loading in the DUDU widget, secondly I want to connect my OBD but the menu for BLuetooth sits blank and I don't actually know if DUDU sees the bluetooth on my Junsun head, the next thing that doesn't work is it doesn't detect when lights are on for example to start the dark theme, the lights on my screen dim but I don't know how to fix DUDU to detect it and last there are system apps from my head like F-CAM which DUDU doesn't see as an app so I can add it to the APP-panel. How can I assist to fix these things?
Your TMPS may not be supported by DUDU; there are too many Android HUs and third-party peripherals, and some functions may not be compatible.
In addition, you mentioned that you cannot add an app. You can try to use the shortcut function in Settings-Others to achieve this.
