pawel17521 Hi, I have the same issue: left/right cameras work, but front/rear cameras do not.
You mentioned that the problem was in the camera plug pins going to the radio. Could you please show or explain the correct pin order?
Was it the 12-pin 360 camera connector at the DUDU unit, or the mini 4-pin camera plug?
A photo of the corrected pins would help a lot. Thanks!
