Hi all,
Someone please help - this install is doing my head in :')
- I have tried a LOT of different wiring configurations and system settings, canbus protocols etc. . I've had all essential functions working at different points, individually, but can not find a configuration that broadly keeps everything working.
- I have a Simple Soft (XP) hy-ss-04 with wiring harness supplied by the seller. Pictured:
The wiring harness was not correct for my vehicle and I have done some modifications. I also have an Aerpro CHHY18C harness that includes a Connects2 steering wheel control interface (CTSKI007.2 Kia Steering Wheel Control Interface. For Digitally Amplified Vehicles). Both claim they should work fairly comprehensively for my application.
- Upon installing, the Aerpro interface harness granted me working steering wheel controls (manual mapping with key 1, key 2 and ground wires), but very quiet and crackly sound. I believe this was because it receives audio through the G cable speaker outs where my amp expects line level output. The hy-ss-04 (with modified harness) gave good quality audio (after eventually finding a compatible canbus profile), but no steering wheel controls. I've attempted to use the two side by side, but this has caused steering wheel controls to stop working. I presume this is because the 2 interfaces are creating a signal conflict.
- I have since tried using the Aerpro harness for steering wheel controls and sending audio to the amp by using the Dudu7 Coaxial SPDIF audio out plug with a single RCA plug patched into the vehicles SPDIF+ and SPDIF- wires. No sound at all AND no steering wheel controls worked with this configuration. More concerning, while a song was playing on the unit, the SPDIF coax RCA out wires were reading zero volts making me think the unit wasn't even sending an audio signal out through this plug. I have not been able to locate a setting to change the audio output path.
2013 Kia Sorento XM SLi,
My OEM head unit pinout, with indication of the wiring present in my specific vehicle
Anyone able to provide some guidance on how to get both steering wheel controls and sound/amp working at the same time?
