Piotrando1 i guess i should first ask if the TPMS is through a canbus, or through their own module.
If it wasn't from the canbus, was it internal or external? If it was from the canbus, you may need to program it/check wiring? I can't comment further if it's through the canbus cause my vehical didn't have a canbus nor TPMS originally.
Did you get a canbus adapter? cause you definitely need one of those since your vehicle has a canbus harness that was wired to your OEM radio (based on what you've said so far that is. idk for sure).
