DUDU-Meng KravtLab See how your screen angle isn't normal? If it's normal, then there's no version of the angle you want to DIY, you need to customize the screen parameters according to the model of your screen to do so
surfer63 KravtLab Do you really have a dudu7? Or do you have a Joying where you run dudos 3.6 beta on. Joying is the only manaufacturer who uses 270 degree rotated screens to display a correct screen.
KravtLab surfer63 I have a DUDU7. I installed a 13-inch display in the place of the 10-inch display. But for the correct installation in the car, I need to flip the display 180 degrees. I did it on an Android radio of a different model.
DUDU-Meng The screen you're using now, take a picture of this for me. I'll see if I can find the parameters for a 270 degree screen
DUDU-Meng Contains multiple angles of this screen of yours. l10p8-mipi-yt129iblxl001-a-1200x1920.7z1kB
KravtLab DUDU-Meng Thanks, the screen turned 180 degrees. The only thing left is the DUDUAUTO screensaver, which is not turned over.
DUDU-Meng KravtLab You can take care of the screensaver yourself. You rotate the image and then just upgrade it with a boot file. Or don't change it. Just use it like this.
