Using the normal layout mode I've set the pip apps settings to change with the light or dark theme. But when I change the default Dudu theme to light or dark the apps (Waze maps and music player BubbleUPnP) don't change. Is this normal?
There is no option in android settings to select auto light or dark theme, only allowing default them as light, dark, custom etc.
Should the apps be changing with dudu theme or must I change them manually each time?
