DUDU-Meng Bjnladjn Settings, About, press and hold the upper left corner of the picture, the pop-up system information screen to take a picture and upload it. If you are dudu3 then connecting bluetooth peripheral is not supported now.
DUDU-Meng DUDU4 does not support built-in Bluetooth. After you change to built-in bluetooth, many bluetooth-related functions will be affected. Please change it back to external Bluetooth and try again.
Bjnladjn DUDU-Meng How to change it, pls? I try to change this code: sys.fyt.bluetooth_type=0 (1, 4, 7), but it's not change ver. I can't to find new Bluetooth firmware too.
DUDU-Meng sys.fyt.bluetooth_type=1 DUDU4 uses this property, OBD you need an external device in the desktop settings to connect it.
DUDU-Meng Bjnladjn You can see OBD in the Bluetooth search list, so you can click on it and select it.
DUDU-Meng Check out this video for yourself, now all DUDU4 users don't have this problem you mentioned, bluetooth is normal. Please keep the firmware on its own bluetooth settings and don't try to change it. https://drive.google.com/open?id=1jEoH37FZ9Jh5_pkidV1U_cy3cwaeXTcp&usp=drive_fs
DUDU-Meng I'm sorry, there was a problem with the Google Drive permission settings, but it's working now.
