【4】If there is an error report, but no corresponding log is generated, you need to capture additional ANR data, the specific steps are as follows, go to Settings-Vehicle-factory set-other-click on the sync ANR option
I am currently driving a 2013 KIA K5 in Korea, and the vehicle is equipped with an AMP. I'm using an Android all-in-one head unit based on the 7862 platform and utilizing the SIMPLESOFT CANBUS. Up to DUDUOS version 3.6 Beta 2, the CANBUS setting worked correctly when set to "IX45 - AMP," and the AMP values were functioning properly. However, starting from Beta 3, the "IX45 - AMP" setting no longer works, and it only operates under the "IX45 - HIGH" configuration.
Additionally, I have noticed that the call volume is somewhat distorted or degraded. When using the air conditioner, the display temperature for the dual-zone (passenger side) no longer updates properly.
I suspect that the CANBUS configuration was altered during the transition from Beta 2 to Beta 3, which caused these issues. Could you please confirm if this is the case? Aside from these problems, everything else appears to be functioning normally.
Thank you very much for your great work in developing your software.
