Since purchasing and installing this unit, i have had problems with its BT connection. it will however connect fine to the Bluetooth OBDII dongle. when I initiate a BT Search in the System Settings as well as Android Settings it will not find my Samsung S24Ultra and the HeadUnit does not appear in scan from phone. I have also tried with other phones but same result. Is there a way to get the firmware for the BT module in the head unit or should i purchase a separate BT dongle and connect that to one of the USB leads in the glovebox and in-turn connect phone via the outboard BT Dongle.
the model purchased is the 8G/128GB Mekede 10 inch HeadUnit. Apart from the BT Issue, i am absolutely delighted with the HU. Also the HU is installed in a 2007 VW Golf GTI (mk5) with Canbus Decoder.
