Is there a way to manually view the backup camera input (RCA).
I find it handy to have on when towing.
Do you have 360 degree cameras? Or just standard RCA backup camera?
If just the single camera, I thought the Recorder app showed it. If not, it seems like a bug.
I put in a Bug Report for this issue because it definitely disables the RCA Camera in the Recorder App when the 360 cameras are enabled.
https://forum.dudu-auto.com/d/1307-reverse-camera-conflict-with-360-rear-camera
I am currently using a standard (rca type plug) backup camera I had installed with the previous head unit that was made specifically to fit my car.
I do however have the 360 chip and cameras, I just haven’t installed the cameras yet.
I did see the the selection of which you want to use in the settings (360 or the standard rca backup plug in) it is set to the standard, and seems to get the reverse signal via Canbus and switches over when reversing correctly.
I also notice the SWC doesn’t seem to function when in reverse and the reverse cam
Input Is brought up.
Will check and see about the recorder app, I’m not using Dudu’s backup camera currently, so maybe its not quite the same (USB vs RCA)? (Although would think it’s purely a matter of toggling on/off that backup rca plug input in the software.)
I am also using Dudu’s 2k front dvr, and have that apk installed and working correctly minus the speed not in mph.
Ok, I figured it out, thanks for where to look deeper.
Just need to get acquainted to the new device.
