  • Issues all coming down to DVR Camera it appears
Following on from my thread about issues with USB music I have been doing some tinkering and I have discovered that my Eonon or generic dvr camera is causing the problems, or so it appears, I am looking for an expert opinion here. When the camera, or either camera is plugged into any usb port it stops the music, but only on the built in player, it doesn't happen on poweramp. So is it simply a compatability issue?? would it be neither an Eonon bog standard DVR usb recorder or generic amazon ADAS camera are compatible?? Is there a list of compatible cameras anywhere or is it just the dudu 2k one that can be used.
Secondly I was having problems with DAB reception, my reverse camera is wired in at the head unit but not connected in the back, and wire runs up the A-pillar alongside dab antenna wire. In factory settings it was set to have rear camera always on, turning that to off seems to have improved signal(possible EM interference from reverse power wire), I have to take a drive out soon so should tell me if i'm right on that.
I have updated to beta4 but could I make a suggestion to increase number of PIP options from 3 to 4(or even more) so its possible to flick between more programs
This is where you can share your experiences, tips and tricks with other DUDU OS users. Explore the possibilities of this innovative platform and learn how to get the most out of your DUDUAUTO device!
