hrscorreia If you are currently using a low level signal connected to the stock AMP, then you can use the USB DAC function of your Android radio and the sound quality will be relatively much better. If there is a noise problem, you can add an audio isolator at the RCA audio interface to solve the noise problem
If you are using a high level signal, there is no better way, or try High to Low.
