  • New Dudu7, few problems
Hello im happy ne user of Duduauto, i got dudu7 model on my Mazda 6 gh from 2008 without BOSE. Sadly i got few problems
1) When i start car ignition screen goes black for a sec, after reboot this doesnt happen for once then it occurs until i reboot again ( new canbus or wires can solve this?)
2) is possible to switch between apps like on phone?
3) Bass is too powerfull even when i turned off dsp and lower bass on equalizer
4) on steering wheel next and previous track is switched on left is next track on right previous it should be opposite.
If someone got similiar problems can share solutions, thank you
    Tekkno84
    Check out settings area, if you have OS 3.5 but should be similar to 3.6 Beta
    Settings - Vehicle - Startup
    Switch to Sleep instead of shutdown, check if this solves your question
    Yes, if I’m thinking of what you are, if you press and hold the home button on the Navbar, this will display all apps opened, you can close or tap to bring apps opened to the front
    Not able to help here, apart from saying to keep playing around in all the areas in the sound master app, what helped me for a Toyota was to take a picture of the equaliser and send it to ChatGPT, believe it or not if gave me values which sound pretty decent to me.
    There may be user saved setups you can apply to try (you need to be connected to the internet to view them)
    This can be changed in settings
    Go to settings - vehicle - factory (input passcode 108)
    There should be an option to swap the track and volume buttons, also door opening indicator they are the wrong way around
    Hope this helps
    thank you for answers,
    1) i got already sleep in options its strange after reboot one time (after car ignition off) radio starts without black screen and every next turn on its goes black. I try to put video.
    2) thanks
    3) ok i try
    4) thanks
    1) Set a 3 seconds delay when turning off the car/ignition.
    This also can stop the DUDU to reboot at automatic start-stop
