• Bug FeedbackSoftware bug reception
  • Bluetooth Phone App doesnt sync the country code the right way; missing "+""
Hi, I have an issue regarding the Bluetooth phone app,
as shown, the Headunit wont show the "+" in front of the country code, which leads to a missdialing. So I´m unable to dial the number over the contacts or last calls.
I´m using a Google Pixel 6
New syncing, as well as deleting the bluetooth connection and repairing dont have shown any improvement so far.
Thx in advance.
Click to download
Please install this application to test if it fixes the problem
After you install the latest version, you can use this icon to update and sync your contacts to prevent the previous data from affecting the display.
Maybe I'm to dumb ... But I don't get it through installation... I disabled play protect.
    DarkHorizon and it says alway installation failed ... I'm also unable to remove the app at first and then installe the new one
      DarkHorizon
      First, check if you have downloaded the file correctly.
      What problem have you encountered? Take a photo.
      DarkHorizon The file you downloaded should be corrupted, please check it The file size is about 16MB.
      4 days later
      Hi, yes the file has 16MB. I tried to install it from the usb stick directly and also tried it to install from root after moving it to the Headunit.
      I also now installed Beta 3 and the issue is still there.
      What country are you from?
      Do you store contacts with a save (+)?
      Is the last call record a direct dial record from a cell phone?
      What should the displayed number normally look like?
      In our tests, the saved numbers and call logs can be displayed.
      They can be dialed normally.
      What's the problem on your end? Please explain.
