  • Can't pair OBD Dongle with code 1234
Bladerunner666 where exactly you found the option to add custom key? I'm stuck with this too.
cifu You just can pair OBD adapter thats named OBDII.
No Vgate.
I hope that FYT will find a way so we can pair every OBD2 adapter.
    JhonnyD Sorry I mean where is that option to insert custom bluetooth password? My one is a Konnwei and it does not need a password however I can't find the setting where I can set a blank password.
      JhonnyD Thanks buddy. Will try tomorrow.
      I have the DUDU 6 and the setting to change the default bluetooth pairing pin was here:
      Settings > Built-in App > BT Phone > Pairing Password
      Or pair through the Android system settings, you can give the code there. I paired my vGate that way.
        gismo And our Vgate is working with DUDU OS?
        Please don't tell nonsense to people.
        It is hard enough for some people to pair their ELM_327 adapter to show data via obd.
        I have 2 different vgate here and i can't pair with vgate android just vgate ios, and this doesn't show data from obd in DUDU OS.
        Maybe you should show us in a vidro?
          In my case neither Dudu menu nor Android menu could pair konnwei obd dongle. Car Scanner App could successfully pair and connect it.
          JhonnyD it works with 3rd party apps installed on DuduOS. It doesn't work with DuduOS' internal functionality. But it's paired and I understood the question to be related to pairing.
            gismo understood.
