Does the mic on the front panel of the DUDU7 work reasonably well? Or should I plan to install the external mic somewhere (and if so, suggestions as to where?)?
And also, does anyone know if DUDU7's 4G LTE radio will work with ATT?
I'm waiting on the correct harness to arrive to get mine installed, but trying to plan out that installation work a bit better than last time. I already ordered an adapter cable to go from HFC III (Toyota's connector) to Fakra so that I can use my van's built in GPS antenna, but not sure if I should plan to install the LTE antenna it came with and/or the external mic.
