• Update Bulletin
  • DUDU Launcher Global Updated & Download
Regis This you must ask the devs. Also Spanish guys want this but the answer is “not at the moment”. I am a simple meber here like you
Private Signature version 1.011010 download STILL NOT WORK
When trying to install any of the APKS it says "not compatible with your device"
But when I try the "BYD" version from telegram it works?
7 days later
Como uno puede acceder a la versión pública signature (o tener permiso de sistemas elevados) gracias
6 days later
YAOXILONG
Hello!! I have a Hizpo W1 car radio (QF005). I would like to know if the public signature version works without problems on my radio. Thank you so much!!!
Cómo puedo comprar una licencia DUDU y que beneficios me entrega
Hi, i am not shure if this was already requested, but i didn‘t found it in search.
I have a mekede/navifly unit for w212, 10,25 inch, 1920x720, snapdragon 685, 8 gb ram.
Is it possible to rum the dudu OS on it?
Thanks, you doing a damn good job!
    MihaiFlorin
    Thx for the answers! Sorry for scam, I`ve read now the faq section. I have an opportunity to send the unit back, and get instead an unit with 7862s/8gb ram/1600x720 screen.
    5 days later
    5 days later
    Meno702 do you resolve it? I have the same problem with UIS7870 (FYT7870) with display 2k (Junsun V3 Plus 9.5")
    I am trying to install dudu launcher pro downloaded from the first and second link.
    I have a FYT7870 (Junsun V3 Plus) with display 9.5" and 2k resolution with Android 13.
    I download it, I give the permission for the thirth party apk and after a popuo is showed which tells "application not installed". Why?
    Peut-être as tu une autre version déjà installée, si c'est le cas désinstalle la avant
    4 days later
    wolf-jr Simply said NO. There is no beta testing for general FYT 7870. You can have DUDU OS on 7870 processor only if you buy a DUDU device. But you can use the launcher. Depending on your device you must use the public signature or the private signature version.
      MihaiFlorin ya. i already hopeless to find a way to install full DUDU OS on FYT 7870. So i only as if i can use the launcher.
        wolf-jr Without serial number registration from DUDUAUTO we never will be able to get it to work.
        Maybe one time there will be a mod, who knows 😉
          8 days later
          Does this launcher support 2 or 3 apps or widgets on the home screen? On my DUDU7 with v3.5 update, it supports two or three apps on home screen, where I can run youtube/music/video and Maps side by side and apps list in the third column.
            abidali
            The launcher supports at least 2 PIP windows on FYT units. On other brands it only supports one PIP window.
            the NavBar and widgets itself are supported. the widgets that show car info might not work though (but do not always show info either on dudu7).
            muito top mesmo essa laucnher
            I need some advice. My friend in Europe who owns a BYD Atto 3 installed Dudu Launcher, but the left-side menu doesn't appear. This prevents them from accessing any settings. How can this be fixed?
            4 days later
            Hi all. Based on the description of Dudu Launcher functionalities, where one of them is the ability to interact with Head-up Display (HUD), is it possible to adjust feature of existing HUD in a car, like adding navigation? For example, in my country, BYD Seal does not have navigation built-in into its HUD (unlike Chinese version).
            6 days later
            I have a TS10 like others but no matter what I do the Public version is never able to install. It looks as though it's running and them simply states "App not installed". I'm still searching for the issue and will report back if/when I locate one.
            I've made sure 'Install apps from unknown sources' is enabled. I've not yet attempted an adb install but perhaps I may do that at some point.
            Hello, when I try installing it I receive the error "App not installed as package conflicts with an existing package."
            How do I resolve this so I can install it?
            This is on a CHSTEK 7862 system, installing the public version. I am aware of other owners of the same device who have been able to install the DUDU launcher from this site.
            Thank you.
              YAOXILONG
              Hello. Happy Chinese New Year!
              Can you provide dudu launcher version with public signature for Changan cs75plus please? Last one gives an error: "Package has no signatures that match those in shared user android.uid.system."
              I need the PIP version. Thank you in advance!
              What is the advantage of using the Dudu OS on my unit instead of just this launcher? I've tried the launcher and it works well.
                Does this launcher work on FYT 7862s Android 12 (SP1A)? The launcher with two PiP on home screen?
                  abidali I don't think it will work on Android 12 7862. It has its own private signature, which doesn't match with the public signature with Android test key like Android 10 version of 7862.
                  Rev Would be interested in this too. I have held installing DuduOS because my HU only has 2GB RAM, which is below the recommended spec. But so far Dudu Launcher is working quite nicely despite the limited RAM
                  Ola, eu tenho uma multimidia lelong le-6321, mais não consigo instalar esta versão 1.013003 do Public Signature, alguem poderia me ajudar com isso ?
                  Hello, I have a Lelong Le-6321 multimedia device, but I can't install this version 1.013003 of the Public Signature, could someone help me with this?
                  @YAOXILONG
                    jjsabadini If the Public signature doesn't work, try with the private signature version
                    4 days later
                    YAOXILONG Sorry for the late reply but I wanted to make sure the launcher installed had PIP. I try to ensure the PIP maps is available but doesn't seem to be on the one that installs.
                    YAOXILONG
                    PIP works on android versions 9 or 10. PIP is not available on android 12 and higher. Is it possible to upgrade the android version in the application so that PIP becomes available on android 12 and higher?
                    6 days later
                    8x ARM cortex A53 - qualcomm
                    msm8953 for arm64 - aarch64 - api level 29
                    ram 4/ rom 128
                    please help me launcher. i don't known opption laucher.
                    Public Signature version or Private Signature version or Qualcomm Signature version
                      phandinh8999 I would say try the Qualcomm first, then the Private version. The Public one definitely won't work on your HU unfortunately
